Ir para o conteúdo principal
Dell Inspiron 11 i3147 Camera Replacement
O que você precisa
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: passo 1, imagem 1 %32
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: passo 2, imagem 1 %32
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: passo 4, imagem 1 %32
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: passo 5, imagem 1 %32
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: passo 6, imagem 1 %32
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: passo 7, imagem 1 %32
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: passo 8, imagem 1 %32
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: passo 9, imagem 1 %32
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: passo 10, imagem 1 %32
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: passo 11, imagem 1 %32
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: passo 12, imagem 1 %32
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: passo 13, imagem 1 %32 Dell Inspiron 11 i3147 Camera Replacement: passo 13, imagem 2 %32
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: passo 15, imagem 1 %32
    • Use a plastic opening tool to take the camera module off the display.
Conclusão
Muhammad Erchid
Membro desde: 10/09/18
1.069 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 223
