Introdução
In this guide, we will be showing you how to remove and replace the Display Hinges.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer. After working inside your computer, follow  the instructions in After working inside your computer. Peel the tapes and remove the antenna cables from the routing guide on the  hinge cover.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
  2. Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
    • Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Lift the display hinges  off the display back-cover and antenna assembly. Lift the display hinges  off the display back-cover and antenna assembly.
    • Lift the display hinges off the display back-cover and antenna assembly.
  5. Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
  6. Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
    • Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
  7. Route the antenna cables through the routing guide on the hinge cover and  secure it in place. Route the antenna cables through the routing guide on the hinge cover and  secure it in place.
    • Route the antenna cables through the routing guide on the hinge cover and secure it in place.
Conclusão
Terrence15
70.334 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 34
