Ir para o conteúdo principal
Dell Inspiron 10z 1120 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 10z 1120 Hard Drive Replacement, Sliding the Hard Drive: passo 2, imagem 1 %32
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-drive: passo 3, imagem 1 %32
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-Drive: passo 5, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 1 %32 Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 2 %32
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: passo 8, imagem 1 %32
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Two Screws: passo 9, imagem 1 %32
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 323
