Introdução
In this guide, we will show you how to remove and replace the Hard Drive.
O que você precisa
Remove the two screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Replace the two screws that secure the hard-drive assembly to the computer base.
