Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Peças
Nenhum componente especificado.
  1. Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
  2. Take off the keyboard.
    • Take off the keyboard.
  3. Unscrew the surface under the keyboard and remove top plate from the base. Unscrew the surface under the keyboard and remove top plate from the base.
    • Unscrew the surface under the keyboard and remove top plate from the base.
  4. Take the battery out by unscrewing the 5 screws and pulling straight off. Take the battery out by unscrewing the 5 screws and pulling straight off.
    • Take the battery out by unscrewing the 5 screws and pulling straight off.
  5. Remove the hard drive.
    • Remove the hard drive.
Conclusão
2 outras pessoas concluíram este guia.
Adicione um comentário
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 88
All Time: 1,270
