Ir para o conteúdo principal
Dell Inpiron 3542 Motherboard Replacement
O que você precisa
  1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: passo 1, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement, Motherboard: passo 1, imagem 2 %32
    • Slide the latches on both sides of the laptop outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inpiron 3542 Motherboard  Replacement: passo 2, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 2, imagem 2 %32
    • Remove the screw. (1 x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inpiron 3542 Motherboard  Replacement: passo 3, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 3, imagem 2 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 3, imagem 3 %32
    • Move the hard drive to the open area and remove it.
  4. Dell Inpiron 3542 Motherboard  Replacement: passo 4, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 4, imagem 2 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 4, imagem 3 %32
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the wireless card from the laptop.
  5. Dell Inpiron 3542 Motherboard  Replacement: passo 5, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 5, imagem 2 %32
    • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
    • Turn over the laptop and open it.
  6. Dell Inpiron 3542 Motherboard  Replacement: passo 6, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 6, imagem 2 %32
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
  7. Dell Inpiron 3542 Motherboard  Replacement: passo 7, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 7, imagem 2 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 7, imagem 3 %32
    • Unplug the touch pad cables located on the palm rest.
    • Remove the screws. (3 x M2.5 x 5mm)
  8. Dell Inpiron 3542 Motherboard  Replacement: passo 8, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 8, imagem 2 %32
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  9. Dell Inpiron 3542 Motherboard  Replacement: passo 9, imagem 1 %32
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  10. Dell Inpiron 3542 Motherboard  Replacement: passo 10, imagem 1 %32
    • Loosen the cables on the antenna.
  11. Dell Inpiron 3542 Motherboard  Replacement: passo 11, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 11, imagem 2 %32
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  12. Dell Inpiron 3542 Motherboard  Replacement: passo 12, imagem 1 %32
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  13. Dell Inpiron 3542 Motherboard  Replacement: passo 13, imagem 1 %32 Dell Inpiron 3542 Motherboard  Replacement: passo 13, imagem 2 %32
    • Unplug the cable on the bottom part of the mother board.
    • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
    • Remove the motherboard from the laptop.
Conclusão
5 outras pessoas executaram este guia.
Rachel lindsey
Membro desde: 03/21/17
718 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team S46-G1, Bennett Spring 2017 Membro de Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
Membros da 3
Autoria de 7 guias
Um comentário
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 3,552
