Ir para o conteúdo principal
Dell G7 15-7588 RAM Replacement
O que você precisa
  1. Dell G7 15-7588 RAM Replacement, RAM: passo 1, imagem 1 %32 Dell G7 15-7588 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Use a Phillips #00 screwdriver to unscrew the 2 mm screw that secures the bottom cover.
    • This screw can not be fully removed from the bottom cover. It will only lift the back cover up the laptop up and allow it to be removed.
    • This will raise the bottom cover of the laptop centered around the screw, providing a easy point to remove the laptop back from later.
  2. Dell G7 15-7588 RAM Replacement: passo 2, imagem 1 %32
    • Remove the bottom cover from the laptop by pulling back the cover.
    • It is recommended to start from where the screw near the top of the laptop lifts the cover.
  3. Dell G7 15-7588 RAM Replacement: passo 3, imagem 1 %32 Dell G7 15-7588 RAM Replacement: passo 3, imagem 2 %32 Dell G7 15-7588 RAM Replacement: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 2.5 mm screws from the battery brackets.
  4. Dell G7 15-7588 RAM Replacement: passo 4, imagem 1 %32
    • Grab both sides of the battery connector.
    • Pull the battery connector straight back to disconnect it from the laptop.
    • This will completely disconnect the batter from the laptop.
  5. Dell G7 15-7588 RAM Replacement: passo 5, imagem 1 %32 Dell G7 15-7588 RAM Replacement: passo 5, imagem 2 %32
    • Push the sides of the metal retention clips outward.
    • This will release the RAM from its locked state and cause it to rise upward, allowing for removal.
    • The same method is used for both pieces of RAM.
  6. Dell G7 15-7588 RAM Replacement: passo 6, imagem 1 %32 Dell G7 15-7588 RAM Replacement: passo 6, imagem 2 %32
    • Remove the RAM from the laptop by pulling it up from the slot.
Conclusão
Ryan Peschke
Membro desde: 02/21/22
141 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 448
