Ir para o conteúdo principal
Dell G3 15 3579 RAM Replacement
O que você precisa
  1. Dell G3 15 3579  RAM Replacement, RAM: passo 1, imagem 1 %32
    • Make sure the laptop is off.
    • Lay the laptop on its front so the bottom is facing up.
  2. Dell G3 15 3579  RAM Replacement: passo 2, imagem 1 %32
    • Use the Phillips #0 to remove the eight screws (M2.5x6) on the bottom of the laptop.
    • Use the Phillips #0 to loosen the two captive screws (M2.5).
  3. Dell G3 15 3579  RAM Replacement: passo 3, imagem 1 %32 Dell G3 15 3579  RAM Replacement: passo 3, imagem 2 %32 Dell G3 15 3579  RAM Replacement: passo 3, imagem 3 %32
    • Use your hands or an opening tool to gently pry the bottom panel off, starting from the left hinge.
    • Continue prying from the bottom to the right side of the back panel and lift it off.
  4. Dell G3 15 3579  RAM Replacement: passo 4, imagem 1 %32 Dell G3 15 3579  RAM Replacement: passo 4, imagem 2 %32
    • Gently unplug the battery connecter from the motherboard.
  5. Dell G3 15 3579  RAM Replacement: passo 5, imagem 1 %32 Dell G3 15 3579  RAM Replacement: passo 5, imagem 2 %32 Dell G3 15 3579  RAM Replacement: passo 5, imagem 3 %32
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
  6. Dell G3 15 3579  RAM Replacement: passo 6, imagem 1 %32 Dell G3 15 3579  RAM Replacement: passo 6, imagem 2 %32
    • Gently align the new RAM with the tab on the slot.
    • Then slide it firmly into the slot at an angle and press the RAM down until it clicks into place.
    • If you do not hear the click, remove the RAM and reinstall it.
  7. Dell G3 15 3579  RAM Replacement: passo 7, imagem 1 %32
    • Align the bottom cover with the slots of the laptop and snap it into place.
    • Tighten the two captive screws (M2.5) to secure the bottom cover.
    • Replace the eight screws (M2.5x6) to secure the bottom cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 92
Duração total: 4,176
