Introdução
This guide provided detailed instructions on how to upgrade the RAM module for the Dell G15 5511 Laptop. Upgrading a laptop's RAM module will boost gaming or multitasking performance.
O que você precisa
Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
Use a Phillips #1 screwdriver to loosen the four captive screws.
Insert an opening pick between the bottom-left corner of the back cover and the chassis.
Pry up to release the clips securing the back cover.
Grip the front of the back cover and lift it away from the laptop.
Pull the back cover towards you to disconnect the clips along the top of the back cover.
Remove the back cover.
Locate the component in the circle area, the battery connector on the motherboard.
Carefully grasp the connector by its side and pull it away from the mother board.
