Ir para o conteúdo principal
Dell Dimension 4600 Side Panel Replacement
  1. Dell Dimension 4600 Side Panel Replacement, Side Panel: passo 1, imagem 1 %32
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Side Panel Replacement: passo 2, imagem 1 %32
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Side Panel Replacement: passo 3, imagem 1 %32
    • Grab the edge of the panel and slide it away from the case until it is removed.
Conclusão
10 outras pessoas executaram este guia.
Daniel Crawford
Membro desde: 10/10/11
1.021 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-10, Regan Fall 2011 Membro de Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membros
Autoria de 11 guias
2Comentários do guia
I can't get the panel off
Diego Vega - Responder Compartilhar
Thanks, worked perfectly, very much appreciated!
Bodhi Goforth - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 22
Últimos 30 dias: 57
Ao todo: 22,852
