Ir para o conteúdo principal
Dell Desktop Optiplex 960 RAM Replacement
  1. Dell Desktop Optiplex 960 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Back up all files and shut the computer down safely.
  2. Dell Desktop Optiplex 960 RAM Replacement: passo 2, imagem 1 %32 Dell Desktop Optiplex 960 RAM Replacement: passo 2, imagem 2 %32
    • Carefully unplug the cords located at the back of the computer (i.e. Power, Monitor, USB, etc).
    • Switch off the electrical connection before unplugging any cords to avoid electric shock.
  3. Dell Desktop Optiplex 960 RAM Replacement: passo 3, imagem 1 %32
    • Pull the trigger located at the bottom of the desktop to unlock the desktop back. This may look different on each individual's computer.
  4. Dell Desktop Optiplex 960 RAM Replacement: passo 4, imagem 1 %32
    • Gently lift up the side panel by pulling it upward while holding the trigger.
  5. Dell Desktop Optiplex 960 RAM Replacement: passo 5, imagem 1 %32 Dell Desktop Optiplex 960 RAM Replacement: passo 5, imagem 2 %32
    • To unlock the RAM, press down the two clips/buttons located on both end of the RAM holder.
  6. Dell Desktop Optiplex 960 RAM Replacement: passo 6, imagem 1 %32
    • Unplug the RAM from the slot.
  7. Dell Desktop Optiplex 960 RAM Replacement: passo 7, imagem 1 %32
    • Ensure that your new RAM chip matches the same shape as the one you removed from your computer.
  8. Dell Desktop Optiplex 960 RAM Replacement: passo 8, imagem 1 %32 Dell Desktop Optiplex 960 RAM Replacement: passo 8, imagem 2 %32
    • Place the new RAM chip into the slot and gently press it down until the clips on either side clasp around it.
  9. Dell Desktop Optiplex 960 RAM Replacement: passo 9, imagem 1 %32
    • Press the wall of the computer back into place until you hear a click from the lock engaging.
  10. Dell Desktop Optiplex 960 RAM Replacement: passo 10, imagem 1 %32 Dell Desktop Optiplex 960 RAM Replacement: passo 10, imagem 2 %32
    • Plug the cords back and power on your computer.
    • Your computer should be back up and running.
Conclusão
After completing steps 1-12, your PC will be up running successfully. If the see your computer is still showing issues, repeat the instructions carefully. However, if the device is still not running properly, the problem is associated with the hardware (RAM), which is not considered for this guideline.
Mercedes Carter
Membro desde: 03/03/20
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 754
