Introdução
This guide should be followed closely before attempting to repair your device. Follow the steps in great detail to ensure the success of your repair.
O que você precisa
Inspect your device and be sure that it matches the device that this guide is disassembling.
Familiarize yourself with the specific design of the device.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
Uma outra pessoa concluiu este guia.
