Ir para o conteúdo principal
Dell Chromebook 3180 LCD Replacement
O que você precisa
    • Open the chromebook until its completely flat on the table
    • Remove both the left and right hinge caps
    • Remove a total of 4 screws. One in each corner.
    • Use a plastic pry tool or blade and start in the top left corner or first left plastic ridge.
    • Lift up the LCD screen from within the LCD assembly frame.
    • On the back of the LCD screen, remove the tape and LCD connector
    • Attach the LCD connector
    • re-apply the tape to the LCD connector
    • Set the new LCD screen into the LCD assembly frame while matching up the screw ports in each corner
    • When installing the LCD bezel, look for the plastic hinge outlines on each side and match them up with the metal hinges on the chromebook.
    • Snap the LCD bezel in place until it is flush with the entire LCD assembly
Conclusão
Uma outra pessoa concluiu este guia.
Jon
Membro desde: 08/18/13
3.921 Reputação
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 789
