Introdução
This guide will show you how to remove and replace the charging port for your Chromebook 3180.
O que você precisa
Remove the 7 screws from the back cover with a Phillips #0 screwdriver
Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
Using a Phillips #0, remove the 2 screws from the right side hinge.
Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
Remove the 2 charging port screws
Unplug the charging port connector from the Motherboard
Disconnect the charging port connector from the motherboard.
Replace the charging port if needed by connecting the new charging port connector to the motherboard.
Using a Phillips#0, replace the 2 charging port screws.
Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
Secure with the 2 screws using your phillips #0.
4 outras pessoas executaram este guia.
Um comentário
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
