Ir para o conteúdo principal
Dell Chromebook 3180 Charging Port Replacement
O que você precisa
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: passo 1, imagem 1 %32 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: passo 1, imagem 2 %32
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: passo 5, imagem 1 %32
    • Secure all 7 screws with a Phillips #0
Conclusão
4 outras pessoas executaram este guia.
Jon
Membro desde: 08/18/13
3.921 Reputação
Autoria de 22 guias
Um comentário
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,069
