Ir para o conteúdo principal
Dell Chromebook 3100 2-in-1 Battery Replacement
O que você precisa
  1. Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Battery Replacement: passo 2, imagem 1 %32 Dell Chromebook 3100 2-in-1 Battery Replacement: passo 2, imagem 2 %32
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: passo 3, imagem 1 %32 Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Battery Replacement: passo 4, imagem 1 %32 Dell Chromebook 3100 2-in-1 Battery Replacement: passo 4, imagem 2 %32 Dell Chromebook 3100 2-in-1 Battery Replacement: passo 4, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Battery Replacement: passo 5, imagem 1 %32 Dell Chromebook 3100 2-in-1 Battery Replacement: passo 5, imagem 2 %32
    • Carefully remove the battery from the device.
Conclusão
Maria Williams
Membro desde: 09/02/21
254 Reputação
Autoria de 1 guia
Equipe
Gateway, Team 1-1, Pee Fall 2021 Membro de Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 52
Duração total: 1,368
