Ir para o conteúdo principal
Dell Chromebook 13-7310 Network Card Replacement
O que você precisa
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: passo 1, imagem 1 %32 Dell Chromebook 13-7310 Network Card Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: passo 3, imagem 1 %32
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: passo 4, imagem 1 %32
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: passo 5, imagem 1 %32
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: passo 6, imagem 1 %32 Dell Chromebook 13-7310 Network Card Replacement, Network Card: passo 6, imagem 2 %32
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: passo 7, imagem 1 %32
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: passo 8, imagem 1 %32
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
Conclusão
Brett Raymond
Membro desde: 11/01/18
469 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 540
