Introdução
A damaged motherboard is a serious issue and can be a hassle to fix, but it doesn't have to be! By following the quick and easy motherboard replacement guide you can have your Chromebook working again in no time!
O que você precisa
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
Um comentário
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
