Ir para o conteúdo principal
Dell Chromebook 13-7310 IO Board Replacement
O que você precisa
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: passo 1, imagem 1 %32 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: passo 3, imagem 1 %32
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: passo 4, imagem 1 %32
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: passo 5, imagem 1 %32
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: passo 6, imagem 1 %32
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: passo 7, imagem 1 %32
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: passo 8, imagem 1 %32
    • Remove the IO board.
Conclusão
Damon
Membro desde: 11/01/18
181 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 321
