Ir para o conteúdo principal
Dell Chromebook 13-7310 Cooling Fan Replacement
O que você precisa
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: passo 1, imagem 1 %32 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: passo 4, imagem 1 %32 Dell Chromebook 13-7310 Cooling Fan Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Conclusão
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 481
