Ir para o conteúdo principal
Dell Chromebook 13-7310 Battery Replacement
O que você precisa
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Dell Chromebook 13-7310 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: passo 4, imagem 1 %32
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: passo 5, imagem 1 %32
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Conclusão
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,258
