Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
Pull out the battery from inside the laptop.
Gently remove the 4-pin connector that connects the speakers to the motherboard.
Remove the tape securing it to the plastic casing of the device.
Carefully lift out the right speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
Moving down the cable, remove the left speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
Uma outra pessoa concluiu este guia.
