Ir para o conteúdo principal
Dell Chromebook 11-3120 Bottom Base Cover Replacement
O que você precisa
  1. Dell Chromebook 11-3120 Bottom Base Cover Replacement, Remove screws: passo 1, imagem 1 %32
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Bottom Base Cover Replacement: passo 2, imagem 1 %32 Dell Chromebook 11-3120 Bottom Base Cover Replacement: passo 2, imagem 2 %32
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
Conclusão
Dalton D
Membro desde: 12/08/17
2.578 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 308
