Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the device over so the bottom is facing up
Remove the 7 visible Philips screws from the device's bottom cover
Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
Remove the two silver screws that hold the battery to the case
Lift the battery straight out of the case and place it in a safe, static-free place
