Ir para o conteúdo principal
Dell Chromebook 11-3120 Battery Replacement
O que você precisa
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: passo 1, imagem 1 %32
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: passo 2, imagem 1 %32 Dell Chromebook 11-3120 Battery Replacement: passo 2, imagem 2 %32
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: passo 3, imagem 1 %32
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: passo 4, imagem 1 %32
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
Conclusão
Dalton D
Membro desde: 12/08/17
2.596 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 408
