Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel. Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released. Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
Linha de Chegada
4 outras pessoas concluíram este guia.
Joseph Silveira
Membro desde: 19/10/2017
401 Reputação
3 Guias de autoria
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 315
