Introdução
The LCD screen is the main method for a device to portray information to the user. Even the slightest bit of damage to this can cause major changes in the display, and will require a replacement.
O que você precisa
Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
Locate the two hinges on the corners of the device.
Unscrew the 5 2mm Phillips #00 screws in the hinges.
Pull the hinges up and slide bottom cover out
Locate the seam between the screen cover, and the top panel
Starting at one of the hinge corners, take a thin metal prying tool and gently insert it into the seam.
Gently push the tool down towards the top panel until you feel the screen cover disconnect.
Repeat this process all around the screen cover until it is completely disconnected from the top panel.
Locate 6 2mm phillips #00 screws that connect the LCD display to the screen panel.
Unscrew the 6 2mm Philips #00 screws.
Carefully flip the LCD display, which is still connected to the device, over the hinges so that it is laying down next to the screen panel.
4 outras pessoas executaram este guia.
