Ir para o conteúdo principal
Dell Chromebook 11 CB1C13 Battery Replacement
O que você precisa
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, imagem 2 %32 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: passo 2, imagem 1 %32 Dell Chromebook 11 CB1C13 Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: passo 3, imagem 1 %32 Dell Chromebook 11 CB1C13 Battery Replacement: passo 3, imagem 2 %32
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Conclusão
To replace your Dell Chromebook 11 battery, follow these instructions in order.
Jerry Geffrard
Membro desde: 03/25/15
334 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,350
