Ir para o conteúdo principal
Dell Chromebook 11 3189 Display Assembly Replacement
O que você precisa
  1. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Display Hinge: passo 1, imagem 1 %32
    • Lift the display assembly away from the computer.
  2. Dell Chromebook 11 3189 Display Assembly Replacement, Place the Display Assembly: passo 3, imagem 1 %32
    • Place the display assembly to align with the screw holders on the computer.
  3. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Screws: passo 4, imagem 1 %32
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  4. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Sensor Cable: passo 5, imagem 1 %32
    • Flip over the computer and connect the sensor cable on the system board.
  5. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Display Cable: passo 6, imagem 1 %32
    • Connect the display cable to the connector on the system board.
  6. Dell Chromebook 11 3189 Display Assembly Replacement, Securing the Screws: passo 7, imagem 1 %32
    • Place the metal bracket over the (display cable) connector, and tighten the M2.0x3.0 screws to secure the display cable to the computer.
  7. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the WLAN cables.: passo 8, imagem 1 %32
    • Connect the WLAN cables.
  8. Dell Chromebook 11 3189 Display Assembly Replacement, Placing the Metal Bracket: passo 9, imagem 1 %32
    • Place the metal bracket, and tighten the M2.0x3.0 screw to the WLAN cable on the system board.
Conclusão
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.161 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
Um comentário
Hola, he remplazado la pantalla. El montaje perfecto pero no enciende. Hay que hacer algo en concreto? Me refiero para que detecte esta pantalla nueva.
Muchas gracias
jordi fernandez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 1,813
