Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The keyboard is a part that is commonly in need of replacement, whether from liquid spills, debris, or damaged keys. This replacement shouldn't take too much time, but can fix a major pain in the neck.
In the guide images, some other components have been removed for clarity and simplicity, but the keyboard is still replaceable if you just follow the steps listed here.
O que você precisa
Disconnect the ribbon cable from the motherboard. To do this, lift up the black tab hinge securing the ribbon cable and pull the cable up and then out of the port.
13 outras pessoas executaram este guia.
