Introdução
The display hinges of your laptop may need to be replaced. They can get damaged from dropping your computer, or even just from everyday wear. This replacement is a little bit more lengthy, but still very conquerable for someone with minimal experience working with electronics.
O que você precisa
Using a Phillips #0 screwdriver, remove the single 3mm Phillips head screw holding down the small metal bracket that covers where the small black and white wires connect to the motherboard.
Once this screw has been removed. Unplug these two wires by gently puling them up and away from the motherboard. Hold the wire as close to the end as possible.
Once it's separated from the rest of the computer, place the screen assembly face up on your work space.
Using tweezers, remove all four stickers covering screws on the front. Stick these to the computer, a few inches from the screw holes.
Using a Phillips #0 screwdriver, remove all four 3.5mm Phillips head screws from the front of the display assembly.
Using a Phillips #0 screwdriver, remove all four of 2.5mm Phillips head screws from the silver metal bracket.
