Introdução
The battery is a very common part to need to replace on a computer, especially as it becomes older. This is a very straightforward process and will only require removing a few screws and unplugging a cable. It should only take a couple of minutes, and there is little damage to be done.
Ferramentas
Peças
Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
6 outras pessoas concluíram este guia.
