Pular para o conteúdo principal
Introdução
The Dell Axim X30 has 5 buttons on the front of the device below the main screen. This guide will focus on the replacement of the home button, messaging button, navigator button, contacts button, and calendar button.
  1. Remove the four rubber feet with your fingers. Remove the four rubber feet with your fingers.
    • Remove the four rubber feet with your fingers.
  2. Insert the nylon spudger into the battery cover release slot to remove the battery from the device. Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
    • Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
  3. Remove four 12.7mm JIS #0 screws.
    • Remove four 12.7mm JIS #0 screws.
  4. Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel will pop off easily.
  5. Disconnect ribbon cables. You may need to use a little force to disconnect them. Disconnect red and white wired connector for speaker and motherboard battery.
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Remove three 12.7mm JIS #0 screws. Remove three 12.7mm JIS #0 screws.
    • Remove three 12.7mm JIS #0 screws.
  7. Carefully remove motherboard.
    • Carefully remove motherboard.
  8. Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Remove black plastic board. Remove black plastic board.
    • Remove black plastic board.
  10. Remove grey and green membrane buttons. Remove grey and green membrane buttons.
    • Remove grey and green membrane buttons.
Conclusão
Jonathan Gulley
Membro desde: 28-03-2018
181 reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G5, Harley Spring 2018 Membro de IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Membros
2 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 127
