Ir para o conteúdo principal
Dell Alienware M18x R2 Memory Modules Replacement
  1. Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 1 %32 Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 2 %32 Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 3 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Alienware M18x R2 Memory Modules Replacement, Removing the Memory Module: passo 2, imagem 1 %32 Dell Alienware M18x R2 Memory Modules Replacement, Removing the Memory Module: passo 2, imagem 2 %32
    • Remove the memory module from the memory-module connector.
  3. Dell Alienware M18x R2 Memory Modules Replacement, Align the Notch: passo 3, imagem 1 %32 Dell Alienware M18x R2 Memory Modules Replacement, Align the Notch: passo 3, imagem 2 %32
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Alienware M18x R2 Memory Modules Replacement, Sliding the Memory Module: passo 4, imagem 1 %32
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Conclusão
Terrence15
Membro desde: 12/18/17
79.034 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 259
