Ir para o conteúdo principal
Dell Alienware M18x R2 Display Assembly Replacement
O que você precisa
  1. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the Video-Card Connector Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Disconnect and peel off the video-card connector cable from the connectors on the system board.
  2. Dell Alienware M18x R2 Display Assembly Replacement, Pull the Pull-Tab: passo 2, imagem 1 %32
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  3. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the LED Logo Board Cable: passo 3, imagem 1 %32
    • Disconnect the LED-logo board cable from the connector on the system board.
  4. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Close the display and turn the computer over.
    • Remove the screws that secure the display assembly on the computer base.
  5. Dell Alienware M18x R2 Display Assembly Replacement, Note the Routing: passo 5, imagem 1 %32
    • Disconnect the antenna cables from the connectors on the Mini-Card.
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
    • Turn the computer over and open the display.
    • Note the routing of the display cable and LED-logo board cable, and then remove the cables from the routing guides on the palm-rest assembly.
  6. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  7. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Antenna Cables: passo 8, imagem 1 %32
    • Gently slide out the antenna cables through the slot on the computer base.
  8. Dell Alienware M18x R2 Display Assembly Replacement, Moving the Display: passo 9, imagem 1 %32
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  9. Dell Alienware M18x R2 Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
    • Route the display cable and LED-logo board cable through the routing guides on the palm-rest assembly.
  10. Dell Alienware M18x R2 Display Assembly Replacement, Connecting the Display Cable: passo 12, imagem 1 %32
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  11. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Cables: passo 13, imagem 1 %32
    • Slide the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
Conclusão
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.131 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 1,090
