Pular para o conteúdo principal
Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
Peças
Nenhum componente especificado.
  1. WARNING:  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Loosen the captive screws that secure the display cable to the system board.
  2. Using the pull-tab, pull the display cable to disconnect the display cable from the  connector on the system board.
    • Using the pull-tab, pull the display cable to disconnect the display cable from the connector on the system board.
  3. Disconnect the camera cable and infrared cable from the respective system board connectors.
    • Disconnect the camera cable and infrared cable from the respective system board connectors.
  4. Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly. Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
    • Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
  5. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Remove the screws that secure the display assembly to the computer base.
    • Remove the screws that secure the display assembly to the computer base.
  7. Lift the display assembly off the computer.
    • Lift the display assembly off the computer.
  8. Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base. Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
  9. Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly. Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
    • Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
  10. Connect the display cable to the connector on the system board.
    • Connect the display cable to the connector on the system board.
  11. Tighten the captive screws that secure  the display cable to the system board.
    • Tighten the captive screws that secure the display cable to the system board.
  12. Connect the camera cable and infrared  cable to the respective system board  connectors.
    • Connect the camera cable and infrared cable to the respective system board connectors.
Conclusão
Terrence15
Membro desde: 18-12-2017
70.855 reputação
442 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
930 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 20
Todo: 322
