Ir para o conteúdo principal
Dell Alienware M17x R2 Memory Modules Replacement
O que você precisa
  1. Dell Alienware M17x R2 Memory Modules Replacement, Loosen the Screw: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the captive screw that secures the memory-module door to the computer base.
  2. Dell Alienware M17x R2 Memory Modules Replacement, Sliding the Memory Module Door: passo 2, imagem 1 %32
    • Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
  3. Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: passo 3, imagem 1 %32 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: passo 3, imagem 2 %32 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: passo 3, imagem 3 %32
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
  4. Dell Alienware M17x R2 Memory Modules Replacement, Removing the Memory Module: passo 4, imagem 1 %32
    • Remove the memory module.
  5. Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: passo 5, imagem 1 %32 Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: passo 5, imagem 2 %32
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch on the NEW memory module with the tab on the memory module connector.
  6. Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: passo 6, imagem 1 %32 Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: passo 6, imagem 2 %32
    • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 706
