Ir para o conteúdo principal
Dell Alienware M17x R2 Battery Pack Replacement
  1. Dell Alienware M17x R2 Battery Pack Replacement, Turn the Computer Over: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before performing these procedures, turn off the computer, disconnect the AC adapter from the electrical outlet and the computer, disconnect the modem from the wall connector and the computer, and remove any other external cables from the computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Turn the computer over.
  2. Dell Alienware M17x R2 Battery Pack Replacement, Slide the Battery Latch: passo 2, imagem 1 %32
    • Slide the battery latch to the unlock position as shown.
  3. Dell Alienware M17x R2 Battery Pack Replacement, Popping out the Battery Pack: passo 3, imagem 1 %32
    • The battery pack will pop up.
  4. Dell Alienware M17x R2 Battery Pack Replacement, Removing the Battery Pack: passo 4, imagem 1 %32
    • Remove the battery pack.
  5. Dell Alienware M17x R2 Battery Pack Replacement, Aligning the Battery Pack Tabs: passo 5, imagem 1 %32
    • Align the battery pack tabs with the slots in the battery bay.
  6. Dell Alienware M17x R2 Battery Pack Replacement, Sliding the Battery Pack: passo 6, imagem 1 %32 Dell Alienware M17x R2 Battery Pack Replacement, Sliding the Battery Pack: passo 6, imagem 2 %32
    • Slide the battery pack into the battery bay until the battery pack clicks into place.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 1,480
