Ir para o conteúdo principal
Dell Alienware M11x R3 Wi-Fi Card Replacement
O que você precisa
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: passo 1, imagem 1 %32 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: passo 1, imagem 2 %32 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: passo 1, imagem 3 %32
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: passo 2, imagem 1 %32 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: passo 2, imagem 2 %32
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Dell Alienware M11x R3 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Conclusão
Richard Maurice
Membro desde: 03/08/17
534 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 689
