Ir para o conteúdo principal
Dell Alienware 18 Memory Module Replacement
O que você precisa
  1. Dell Alienware 18 Memory Module Replacement, Warning: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: passo 2, imagem 1 %32
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
  3. Dell Alienware 18 Memory Module Replacement, Popping up the Memory Module: passo 3, imagem 1 %32
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: passo 4, imagem 1 %32
    • Remove the memory module from the memory-module connector.
  5. Dell Alienware 18 Memory Module Replacement, Replacing the Memory Module: passo 5, imagem 1 %32
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Dell Alienware 18 Memory Module Replacement, Securing the Memory Module: passo 6, imagem 1 %32
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Linha de Chegada
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
44 Membros
Autoria de 1.996 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 529
