Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Disconnect the hard-drive cable from its connector on the system board.
Loosen the captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
Place the NEW primary hard drive in the hard-drive bracket.
If applicable, slide the secondary hard drive into the hard-drive bracket.
Replace the screws that secure the primary hard drive to the hard-drive bracket.
If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
Place the hard-drive assembly in the computer base.
Tighten the captive screws that secure the hard-drive assembly to the computer base.
Connect the hard-drive cable to its connector on the system board.
