Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ferramentas
Peças
Nenhum componente especificado.
Disconnect the hard-drive cable from its connector on the system board.
Loosen the captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
If applicable, slide the secondary hard drive into the hard-drive bracket.
Replace the screws that secure the primary hard drive to the hard-drive bracket.
If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
Tighten the captive screws that secure the hard-drive assembly to the computer base.
Connect the hard-drive cable to its connector on the system board.
2 outras pessoas concluíram este guia.
