Introdução
In this guide, we will be showing you how to remove and replace the Coin-Cell Battery.
O que você precisa
Use a Phillips screwdriver to remove the three screws securing the base cover.
Slide the base cover towards the rear of the computer and lift it off the computer base.
Disconnect the coin-cell battery cable from its connector on the system board.
Remove the coin-cell battery cable from the routing guides on the computer base.
Pry up the coin-cell battery from the slot on the system board.
Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
Route the coin-cell battery cable through the routing guides on the computer base.
Connect the coin-cell battery cable to its connector on the system board.
Uma outra pessoa concluiu este guia.
