Ir para o conteúdo principal
Dell Alienware 15 R3 SSD Replacement
O que você precisa
  1. Dell Alienware 15 R3 SSD Replacement, Back Case: passo 1, imagem 1 %32 Dell Alienware 15 R3 SSD Replacement, Back Case: passo 1, imagem 2 %32 Dell Alienware 15 R3 SSD Replacement, Back Case: passo 1, imagem 3 %32
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 SSD Replacement: passo 2, imagem 1 %32
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 SSD Replacement, SSD: passo 3, imagem 1 %32
    • Use the Phillips #00 to remove the 3.0 mm screws that secure the cover of the SSD.
    • Remove the cover from the SSD.
    • The cover is not pictured.
    • To prevent losing data, do NOT remove the SSD while the computer is on or in sleep mode.
    • Slide the old SSD card out of the slot.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 27
Duração total: 302
