Introdução
If you are trying to replace the motherboard for the Dell Alienware 15 R3 this is a step by step guide to help you.
O que você precisa
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
Before you begin, disconnect the battery cable from the motherboard. Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the battery cable out.
Use a Phillips #00 screwdriver to remove the eleven screws connecting the fan to the motherboard.
Um comentário
This guide completely skips disengaging the battery, which should be done before any components, and it should be plugged back in last.
