Ir para o conteúdo principal
Dell Alienware 15 R3 Motherboard Replacement
O que você precisa
  1. Dell Alienware 15 R3 Motherboard Replacement, Back Case: passo 1, imagem 1 %32 Dell Alienware 15 R3 Motherboard Replacement, Back Case: passo 1, imagem 2 %32 Dell Alienware 15 R3 Motherboard Replacement, Back Case: passo 1, imagem 3 %32
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Motherboard Replacement, Cover Assembly: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Motherboard Replacement: passo 4, imagem 1 %32 Dell Alienware 15 R3 Motherboard Replacement: passo 4, imagem 2 %32
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Motherboard Replacement: passo 5, imagem 1 %32 Dell Alienware 15 R3 Motherboard Replacement: passo 5, imagem 2 %32 Dell Alienware 15 R3 Motherboard Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Before you begin, disconnect the battery cable from the motherboard. Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the battery cable out.
    • Use a Phillips #00 screwdriver to remove the eleven screws connecting the fan to the motherboard.
  7. Dell Alienware 15 R3 Motherboard Replacement: passo 7, imagem 1 %32 Dell Alienware 15 R3 Motherboard Replacement: passo 7, imagem 2 %32
    • Detach the ribbon cable connecting the heat sink to the motherboard.
    • Pull the heat sink off of the fan.
    • Be careful as you lift it off the fan so it doesn't bend.
  8. Dell Alienware 15 R3 Motherboard Replacement: passo 8, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the eight screws from the motherboard.
    • Detach the remaining ribbon cables from the motherboard.
    • Remove the motherboard from the laptop.
Conclusão
Jake Nelson
Membro desde: 09/22/22
581 Reputação
Autoria de 7 guias
Um comentário
This guide completely skips disengaging the battery, which should be done before any components, and it should be plugged back in last.
Paul Wilson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 57
Duração total: 1,163
