Ir para o conteúdo principal
Dell Alienware 15 R3 Cover Assembly Replacement
O que você precisa
  1. Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: passo 1, imagem 1 %32 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: passo 1, imagem 2 %32 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: passo 1, imagem 3 %32
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Cover Assembly Replacement: passo 2, imagem 1 %32
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Cover Assembly Replacement, Cover Assembly: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Cover Assembly Replacement: passo 4, imagem 1 %32 Dell Alienware 15 R3 Cover Assembly Replacement: passo 4, imagem 2 %32
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Cover Assembly Replacement: passo 5, imagem 1 %32 Dell Alienware 15 R3 Cover Assembly Replacement: passo 5, imagem 2 %32 Dell Alienware 15 R3 Cover Assembly Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 442
