Ir para o conteúdo principal
Dell Alienware 14 Wireless Mini-Card Replacement
O que você precisa
  1. Dell Alienware 14 Wireless Mini-Card Replacement, Close the Display: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: passo 2, imagem 1 %32 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Wireless Mini-Card Replacement, Slide and Lift the Base Cover: passo 3, imagem 1 %32
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: passo 4, imagem 1 %32
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: passo 5, imagem 1 %32
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: passo 6, imagem 1 %32
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnecting the Battery Cable: passo 7, imagem 1 %32
  8. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: passo 8, imagem 1 %32
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Wireless Mini-Card Replacement, Using the Battery Cable: passo 9, imagem 1 %32
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: passo 10, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Wireless Mini-Card Replacement, The Power Button: passo 11, imagem 1 %32
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: passo 13, imagem 1 %32
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Screw Holes: passo 14, imagem 1 %32
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: passo 15, imagem 1 %32
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Battery Cable: passo 16, imagem 1 %32
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: passo 17, imagem 1 %32 Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: passo 17, imagem 2 %32
  17. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screw: passo 18, imagem 1 %32
    • Remove the screw that secures the wireless mini-card to the system board.
  18. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: passo 19, imagem 1 %32 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: passo 19, imagem 2 %32
    • Slide and remove the wireless-mini card from the system-board connector.
  19. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Notch: passo 20, imagem 1 %32
    • Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
    • CAUTION: Use firm and even pressure to slide the wireless mini-card into place. If you use excessive force, you may damage the connector.
    • CAUTION: The connectors are keyed to ensure correct insertion. If you feel resistance, check the connectors on the wireless mini-card and on the system-board connector, and realign the wireless mini-card.
    • CAUTION: To avoid damage to the wireless mini-card, never place cables under the wireless mini-card.
  20. Dell Alienware 14 Wireless Mini-Card Replacement, Inserting the Wireless Mini-Card: passo 21, imagem 1 %32
    • Insert the wireless mini-card at a 45-degree angle into the system-board connector.
  21. Dell Alienware 14 Wireless Mini-Card Replacement, Securing the Wireless Mini-Card: passo 22, imagem 1 %32
    • Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
  22. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Antenna Cables: passo 23, imagem 1 %32
    • Connect the antenna cables to the connectors on the wireless mini-card.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 185
