Ir para o conteúdo principal
Dell Alienware 14 Subwoofer Replacement
O que você precisa
  1. Dell Alienware 14 Subwoofer Replacement, Close the Display: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 2, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Subwoofer Replacement, Slide and Lift the Base Cover: passo 3, imagem 1 %32
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Subwoofer Replacement, Align the Tabs: passo 4, imagem 1 %32
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Subwoofer Replacement, Replace the Screws: passo 5, imagem 1 %32
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Subwoofer Replacement, Turn the Computer Over: passo 6, imagem 1 %32
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Subwoofer Replacement, Disconnecting the Battery Cable: passo 7, imagem 1 %32
  8. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 8, imagem 1 %32
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Subwoofer Replacement, Using the Battery Cable: passo 9, imagem 1 %32
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Subwoofer Replacement, Turn the Computer Over: passo 10, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Subwoofer Replacement, The Power Button: passo 11, imagem 1 %32
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Subwoofer Replacement, Align the Tabs: passo 13, imagem 1 %32
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Subwoofer Replacement, Align the Screw Holes: passo 14, imagem 1 %32
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Subwoofer Replacement, Replace the Screws: passo 15, imagem 1 %32
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Subwoofer Replacement, Connect the Battery Cable: passo 16, imagem 1 %32
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 17, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 17, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Subwoofer Replacement, Lifting the Secondary Hard-Drive: passo 18, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Lifting the Secondary Hard-Drive: passo 18, imagem 2 %32 Dell Alienware 14 Subwoofer Replacement, Lifting the Secondary Hard-Drive: passo 18, imagem 3 %32
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Subwoofer Replacement, Lifting the Hard Drive: passo 19, imagem 1 %32
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Subwoofer Replacement, Turn the Assembly Over: passo 20, imagem 1 %32
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Subwoofer Replacement, Remove the Screw: passo 21, imagem 1 %32
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 22, imagem 1 %32
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Subwoofer Replacement, Slide and Lift the Hard-Drive: passo 23, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Slide and Lift the Hard-Drive: passo 23, imagem 2 %32
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Subwoofer Replacement, Disconnect the Interposer: passo 24, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Disconnect the Interposer: passo 24, imagem 2 %32
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Subwoofer Replacement, Connect the Interposer: passo 25, imagem 1 %32
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Subwoofer Replacement, Placing the Secondary Hard-Drive: passo 26, imagem 1 %32
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Subwoofer Replacement, Align the Screw Holes: passo 27, imagem 1 %32
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Subwoofer Replacement, Replace the Screws: passo 28, imagem 1 %32
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Subwoofer Replacement, Align the Screw Hole: passo 29, imagem 1 %32
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Subwoofer Replacement, Replace the Screw: passo 30, imagem 1 %32
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Subwoofer Replacement, Turn the Hard-Drive Assembly Over: passo 31, imagem 1 %32
  31. Dell Alienware 14 Subwoofer Replacement, Slide the Hard-Drive Cable: passo 32, imagem 1 %32
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Subwoofer Replacement, Align the Screw Holes: passo 33, imagem 1 %32
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Subwoofer Replacement, Disconnecting the Status-Light Board Cable: passo 35, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Disconnecting the Status-Light Board Cable: passo 35, imagem 2 %32
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  34. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 36, imagem 1 %32
    • Remove the screws that secure the palm -rest assembly to the computer base.
  35. Dell Alienware 14 Subwoofer Replacement, Turn the Computer Over: passo 37, imagem 1 %32
  36. Dell Alienware 14 Subwoofer Replacement, Pry the Palm-Rest Assembly: passo 38, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Pry the Palm-Rest Assembly: passo 38, imagem 2 %32
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  37. Dell Alienware 14 Subwoofer Replacement, Lift the Palm-Rest Assembly: passo 39, imagem 1 %32
    • Carefully lift the palm-rest assembly and turn it over.
  38. Dell Alienware 14 Subwoofer Replacement, Release the Connector Latches: passo 40, imagem 1 %32 Dell Alienware 14 Subwoofer Replacement, Release the Connector Latches: passo 40, imagem 2 %32
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  39. Dell Alienware 14 Subwoofer Replacement, Turn the Palm-Rest Assembly: passo 44, imagem 1 %32
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  40. Dell Alienware 14 Subwoofer Replacement, Close the Display: passo 46, imagem 1 %32
  41. Dell Alienware 14 Subwoofer Replacement, Replace the Screws: passo 47, imagem 1 %32
    • Replace the screws that secure the palm-rest assembly to the computer base.
  42. Dell Alienware 14 Subwoofer Replacement, Slide the Status-Light Board Cable: passo 48, imagem 1 %32
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  43. Dell Alienware 14 Subwoofer Replacement, Remove the Screws: passo 49, imagem 1 %32
  44. Dell Alienware 14 Subwoofer Replacement, Disconnecting the Subwoofer Cable: passo 50, imagem 1 %32
    • Disconnect the subwoofer cable from the system-board connector.
  45. Dell Alienware 14 Subwoofer Replacement, Remove the Subwoofer Cable: passo 51, imagem 1 %32
    • Note the subwoofer cable routing and remove it from the routing guide.
  46. Dell Alienware 14 Subwoofer Replacement, Lifting the Subwoofer: passo 52, imagem 1 %32
    • Lift the subwoofer along with its cable away from the computer base.
  47. Dell Alienware 14 Subwoofer Replacement, Using the Alignment Posts: passo 53, imagem 1 %32
    • Use the alignment posts on the computer base to keep the NEW subwoofer in place.
  48. Dell Alienware 14 Subwoofer Replacement, Replace the Screws: passo 54, imagem 1 %32
    • Replace the screws that secure the subwoofer to the computer base.
  49. Dell Alienware 14 Subwoofer Replacement, Route the Subwoofer Cable: passo 55, imagem 1 %32
    • Route the subwoofer cable through the routing guide and connect the cable to the system-board connector.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 248
