Ir para o conteúdo principal
Dell Alienware 14 Battery Replacement
O que você precisa
  1. Dell Alienware 14 Battery Replacement, Close the Display: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Battery Replacement, Remove the Screws: passo 2, imagem 1 %32 Dell Alienware 14 Battery Replacement, Remove the Screws: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Battery Replacement, Slide and Lift the Base Cover: passo 3, imagem 1 %32
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Battery Replacement, Align the Tabs: passo 4, imagem 1 %32
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Battery Replacement, Replace the Screws: passo 5, imagem 1 %32
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Battery Replacement, Turn the Computer Over: passo 6, imagem 1 %32
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Battery Replacement, Disconnecting the Battery Cable: passo 7, imagem 1 %32
  8. Dell Alienware 14 Battery Replacement, Remove the Screws: passo 8, imagem 1 %32
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Battery Replacement, Using the Battery Cable: passo 9, imagem 1 %32
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Battery Replacement, Turn the Computer Over: passo 10, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Battery Replacement, The Power Button: passo 11, imagem 1 %32
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Battery Replacement, Align the Tabs: passo 13, imagem 1 %32
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Battery Replacement, Align the Screw Holes: passo 14, imagem 1 %32
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Battery Replacement, Replace the Screws: passo 15, imagem 1 %32
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Battery Replacement, Connect the Battery Cable: passo 16, imagem 1 %32
    • Connect the battery cable to the system-board connector.
Conclusão
3 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.161 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.988 guias
Um comentário
I took my battery out and lost it. I didn't record the part number. Does anybody around here happen to have it handy?
ignacio - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,954
